I have Shrink 3.2 and Nero Express 6.3.1.25. Nero use to burn automatically after Shrink. Now for some reason Nero won't burn automatically even after go to "Prererences" and check "Burn with Nero". Don't know what I did. Does anyone have any ideas how to fix?
Results 1 to 12 of 12
The uninstall and reinstall fixed it. Thanks
Can you use Shrink and DVD Decrypter like Shrink and Nero?
If so, what are the advantages? -
I use DVD Decrypter with DVDshrink because I never had a bad burn with Decrypter. Can't say the same thing for Nero.
NEC ND3500A/G
Unproper and proud of it -
No, use of the DVD Decrypter with the Nero is better than with the DVDshrink. The DVDshrink is slow and easy to have the error message and then stop running.
In DVDshrink, when you click on "Back-Up", a dialog-box will open.Originally Posted by Beams
Click on the first tab (furthest left) called "Target Device", you'll see two
drive selection fields. The top field is named "Select Backup Target".
Make sure that your burner is designated in this field, otherwise it won't
burn automatically with Nero. -
What he means is that Decrypter is a better ripper than DVD Shrink, I'm guessing. While that's true, that's not the subject being discussed. We are pointing out that Decrypter is a better choice over Nero when burning.Originally Posted by coody
DVD Shrink requires Nero
By jyeh74 in forum Newbie / General discussionsReplies: 42Last Post: 7th Oct 2013, 19:17 -
Nero will burn 4X, DVD Shrink-Nero only 2.5X
By happydog500 in forum DVD RippingReplies: 16Last Post: 4th Jan 2010, 20:49 -
DVD Shrink and Nero together
By moe_b_disc in forum Newbie / General discussionsReplies: 11Last Post: 1st Mar 2008, 15:23 -
Nero Recode vs DVD Shrink
By PhoneMatt in forum DVD RippingReplies: 2Last Post: 8th Feb 2008, 14:04 -
nero 8 & dvd shrink
By jerbevpicasso in forum Newbie / General discussionsReplies: 17Last Post: 24th Oct 2007, 22:36
