Hi, I am trying to join 2 DIVX AVI files to one, so that I can author to DVD.
I looked around but couldn't find how to do it.
I tried the join tool. Didn't check the whole joined file, but at the end there was about a half an hour or more missing.
Any suggestions greatly appreciated.
Multi-GB size files may be not compatible with the AVI format. You could convert each file separately and then use Sizzle to author a single DVD.
You can use MPEG Streamclip to join the mpegs too.
For size control use the bit rate calculator in the video tab to control size.
-Set total time of the movie: total of both parts in minutes
-Select the DVD 4Gig disk option
-Click the rate button
For example: a bit rate of 4400 kbit/s will let a 2 hour movie fit on a single DVD-R or RW.
Cheers
Joining two AVIs in TMPGEnc Xpress
By jeanpave in forum Video ConversionReplies: 17Last Post: 8th May 2010, 23:16 -
? Shrinking Multiple AVIs to Target Total-Size Then Joining to Originals
By Synetech in forum EditingReplies: 2Last Post: 4th Apr 2008, 21:14 -
Joining AVIs - Vdub reports audio streams do not share common sample rate
By Lolipop Jones in forum Video ConversionReplies: 3Last Post: 22nd Jan 2008, 14:32 -
Trouble joining two mp4s (or two avis)
By nosillacast in forum EditingReplies: 2Last Post: 27th Sep 2007, 09:30 -
How can I join several AVIs into one?
By htp367 in forum EditingReplies: 2Last Post: 30th May 2007, 10:06
