i have a:
p3
500mghz
comp-usa home series pc
win98se
and everytime i try to use tv on demand it turns the screen black and crashes?
is it possibe to get this to work? what am i doing wrong?
THANKS!!!!!!!!!!
Results 1 to 14 of 14
You need either the 7.2 mmc or the mmc7.5 I had the same problem with the CD MMC 7.1. Is your PC clock running normal. Mine seems to be running slow.
hi-
what do you mean is my pc clock running slow? do u literally mean the time??? can i get mmc 7.2 or 7.5 at ati.com??
THANKS!!!! -
7.2 can be found at ATI but does not have the DVD player included.
7.5 can be found at subzero. if password need, rade3 i think.
http://www.subzerotech.com/news/files/MmcDvd75.exe
Yes, the time on my PC is losing time. about 20 minutes a day. -
hey thanks for the links!
yes, i did notice the clock loosing time but i fixed the time and now it is fine and has been for awhile.
ps since u changed to 7.2 or 7.5 now your tv on demand works great????
thanks!!!!
I started with 7.1 then upgraded to 7.2 then to 7.5. If you start with 7.5 or 7.2, you loose in demand for some reason.
"how did you fix the clock"
i clicked on the clock and then reset the time and it has kept the correct time since
i cant find mmc 7.2 on the ati site only 7.1, why do you know?
is that the latest version they support only 7.1?
also what type of system do you have? similar to mine
win98se
p3
500mghz
512mb ram
you won't find the drivers under windows 98.
http://support.ati.com/drivers/misc/mmc7_2_nodvd.html
Windows XP
P4 1.6
512 MB ram
40gig HD -
Silly, I suspect that a motherboards chipset has a lot to do with capturing video (duh!).
I can't use TV On Demand either. I've had no luck in Win 98, 2000, and XP.
I have the Via KT133 chipset, and have heard others complain about it.
I'm changing to the KT133a chipset this week and will report. -
"Silly, I suspect that a motherboards chipset has a lot to do with capturing video (duh!)."
i do suspect a little bit of sarcasam HEY sorry i am not as well versed in video capture. Rome wasnt built in a day.
i am working on it!!!!!!!!
should i dl mmc 7.5 to get tv on demand to work? or just stick with 7.1 becuase it will never work with my machine?
thanks
ps i have: Via VT82C693A chipset is that good, bad or indifferent?
THANKS for the help!!!
<font size=-1>[ This Message was edited by: sillyrabbitt on 2001-12-09 20:57:01 ]</font> -
Sorry, I wasn't disin you.
In fact, I made a mistake. My chipset IS the VIA KT133a. -
no problem!!!!! i was just a little frustrated with all this shit!!! it gets so f___ing complicated sometimes
wabbitt
How often do you watch ON DEMAND programming?
By yoda313 in forum PollsReplies: 18Last Post: 3rd Jul 2011, 19:55 -
installing fonts in MKV on demand?
By AlanHK in forum SubtitleReplies: 4Last Post: 16th Nov 2010, 22:01 -
subtitle and movies on demand
By sat-jokar in forum SubtitleReplies: 4Last Post: 16th Jan 2009, 12:41 -
On Demand Streaming
By ZoNE97 in forum Video Streaming DownloadingReplies: 0Last Post: 26th Jul 2008, 20:40 -
New DVD on Demand Solution Launched
By marshyman in forum Latest Video NewsReplies: 0Last Post: 12th Nov 2007, 12:23
