  1. Can anyone recommend a company or person in the Oklahoma City area that really knows all the ins and outs of codecs, and capturing 8mm analog and converting to DVD format? I would need them to come to my home to repair the problem
    I posted many messages last year on my problem of degraded video capture but all the wonderful people here finally gave up as nothing worked. Thanks.
    Mick
  2. Member Leoslocks's Avatar
    May 2003
    By 8mm analog, do you mean film or video? If Video, is it Hi8 or just 8?
  3. It's just straight 8mm video from my camcorder.
    Mick
  4. Member Leoslocks's Avatar
    May 2003
    First. the experience gained in you initial endevor will help if you choose to try to capture/edit/encode/author/burn a DVD.
    Have a look at the DVD Recorder section. You would be amazed at the quality they are producing. The most difficult part would be connecting the camera and TV to the unit.
  5. I read your earlier posts.
    The horizontal lines are interlacing, this is normal, required, in fact, and will NOT be visible on the TV, only on DVD. Hare you burnt a disk using those files and viewed it on the final output device? Have you played direct from the camcorder to that device?
    Whether for re-encode using AVI or real-time MPEG cap, you should use 720x480. This is closest to the native, FIXED res of the card.
    The horizontal lines shown on the PC monitor give a false impression of TV output quality. You should be able to get very close to direct camcorder-to-TV connection quality. Possibly even better using filters but that is a bit more advanced.
  6. Nelson37,
    Thank you for your efforts. I have tried all those suggestions in the past, including filters. The bottom line is the DVD (displayed on a TV) is poor. Something internally is wrong. Someone once suggested a codec is corrupted and may have to reformat the hard drive to fix it.
    One thing I have not tried is borrowing a digital video camera to see if that makes a difference after capturing.
    Mick
  7. A corrupt codec is hardly reason to format a drive.
    We need a lot more info about the whole process you're using, before we can make recommendations.
    Cheers, Jim
    My DVDLab Guides
  8. If someone wants to try to figure this out, I can try to provide all the info again. It just got to the point that no one last year could help as much as they tried. I had run out of options. I was hoping that a codec could not corrupt enough to warrant a reformat. I need to record an event this weekend and distribute an edited verion on DVD. Thanks.
    Mick
    Mick
