Hello,
Is there anybody who know a plugin for Photoshop or a program (in C/C++, fortran ...) to do an edge detction.
Especially i would like to follow an inteface between two liquids with this method using digital video.
Do you have an idea or an advise to me???
Edge detection is not easy or triva. Wrote one years ago to Vectorize a picture. Need to find the edge so to speak.
Check with Adobe. They had a pacakage years ago to "Vectorize" a picture.
One concept is a difference between frames. Same as Mpeg1 or 2 in how it works. Could bring in the "frames" and take the differences of them. The difference would be your edge. You can run into problems. But it may work.
The other is check about ten years back in Dr Dobbs Journal. They had an article on reducing the thickness of "thing" in a bitmap. Search for the word "wild fire". It basically hitting a picture from left-right and top-bottom. You keep hitting it untill you have thined out the object. This. If lucky. May do your edge detect.
Nice video effect to follow.
By arayasg in forum MacReplies: 0Last Post: 7th Oct 2011, 03:33 -
PIO mode detector???
By AlecWest in forum DVD & Blu-ray WritersReplies: 12Last Post: 12th May 2010, 15:49 -
Final year project idea (Pirate DVD detector)
By witchfinder in forum Authoring (DVD)Replies: 8Last Post: 5th Oct 2008, 21:49 -
Interlace/progressive detector
By demonwarrior in forum Newbie / General discussionsReplies: 9Last Post: 6th Dec 2007, 01:35 -
Do you follow a rigid morning routine?
By yoda313 in forum PollsReplies: 11Last Post: 25th Oct 2007, 01:06
