Hello I hope I am posting on the right forum. Here is what I am needing help with. I have some dvd's that I got and they are big enough to fit on one dvd disc but there around 4.3 and 4.2 but I like to have them around 3.8GB or so cause most of my dvd players have problems with playing media that is bigger then 4.0 GB and I know people know what I am talking about. I do use high quality media like Taiyo Uden and Ritek DVD-R for my projects and I have tested time and time again different media and stuff but I like to stay under the 4.0 GB mark just to be safe. Ok here is the problem with dvd shrink I have a file size of 4.3 and I tried to shrink it down to 3.8GB using the settings of shrinking it and it still came out the same size of 4.3 after it did the Transcoding wich took over 42 minutes since I used Deep Analaysis. Is there something i am doing wrong with dvd shrink here and should it still shrink it anyways if I wanted it too even though its alredy the size it is? I have went to doom9 and could not find anything on it. Any help would be appreciated.
heman28
Eric
Did you change to a custom size? under Edit->Preferences and select custom and lower to around 4000MB.
Hello Thanks for the info, I did not know about that setting and I will try it to see how it works.
Eric
Will DVD Shrink shrink an ISO image?
By brassplyer in forum DVD RippingReplies: 26Last Post: 19th Sep 2013, 22:03 -
Problems backing up DL dvds using DVD Shrink and ImgBurn
By ManuBumb in forum Newbie / General discussionsReplies: 9Last Post: 7th Apr 2009, 21:35 -
Will using the pc while using DVD shrink cause problems to editing????
By jones24 in forum DVD RippingReplies: 8Last Post: 7th Oct 2008, 10:39 -
problems with DVD Shrink 3.2.0.15
By janefield in forum Newbie / General discussionsReplies: 6Last Post: 25th Aug 2008, 07:20 -
dvd shrink problems
By anahata3 in forum DVD & Blu-ray WritersReplies: 9Last Post: 9th Jul 2007, 11:07
