Hi,
I have a computer running ProgDVB to receive Radios via a Satellite feed.
I would like to stream these radios to be able to receive them on my Pocket-PC via the Wifi connection.
I know that ProgDVB itself can stream, but this is a proprietary method which requires a ProdDVB client on the receving end. As far as I know there is no version of ProgDVB on WindowsCE.
So I believe the best would be to have :
- A plugin for ProgDVb allowing to stream the sound in a standard format such as shoutcast does.
- Or a standalone program broadcasting the sound from the soundcard like shoutcast does with Winamp. Windows CE players can tune to shoutcast streams, so it would be ideal.
Do you have some ideas about this ?
Thanks.
Results 1 to 1 of 1
ffmpeg Number of stream maps must match number of output streams
By tmiller_15 in forum Blu-ray RippingReplies: 1Last Post: 13th Nov 2010, 07:20 -
Copy two input videos into one output stream
By Nightness in forum Video Streaming DownloadingReplies: 2Last Post: 21st Mar 2010, 20:01 -
capture soundcard output stream
By ted demen in forum AudioReplies: 0Last Post: 6th Mar 2009, 21:07 -
screen capture output to dv stream
By bissquitt in forum Video Streaming DownloadingReplies: 12Last Post: 27th Jun 2008, 04:22 -
failed to connect Output pin 0x0093ae4c ["Stream 00"] on AVI Spli
By carcrashhearts in forum Newbie / General discussionsReplies: 2Last Post: 9th Nov 2007, 13:46
