The ATSC tuner is the DTV tuner for receiving over the air digital broadcasts. ATSC is the digital broadcasting standard in the USA.
Results 31 to 36 of 36
http://www.kiva.org/about -
Originally Posted by GeekFunk
All this talk of Ghosting and I have YET to see it on any the newer LCD's during game play or watching sporting events.
DLP might be fine for a Living Room or Family Room but HARDLY practical for bedroom use, nevermind you'll be sitting right on top of even the smallest versions.
Syntax just released the HVX versions of the 26" and 30" LCD's and they are a big improvement over the HVE series.
Some reviews are already up on the AVS Forums.
Just waiting until Christmas...Project Digital: Eliminate All Physical Media is finally underway! -
LCD's are gradually getting better* and good big affordable ones will be showing up in 2006.
*If you avoid cheap sets with computer monitor panels. Best way to select a LCD panel intended for video display is look for native resolutions in the 1366 x 768 range (or better) and contrast ratios above 1000 to 1. Computer spec resolutions (e.g. 800x600, 1024x768) usually indicate a computer monitor panel.Recommends: Kiva.org - Loans that change lives.
Getting ready to buy 32" LCD
By neworldman in forum DVB / IPTVReplies: 6Last Post: 26th Jul 2010, 12:12 -
dellE228WFP 22" LCD monitor to a time warner cable box?
By Ashypoo19 in forum DVB / IPTVReplies: 1Last Post: 8th Apr 2010, 14:24 -
Is Inspiron Zino HD + I-inc iH-252HPB 25" LCD Monitor =HDTV
By surucu in forum DVB / IPTVReplies: 1Last Post: 26th Nov 2009, 08:59 -
Toshiba HD DVD player to Dell LCD 17" monitor
By jascman217 in forum Newbie / General discussionsReplies: 3Last Post: 16th Sep 2009, 21:24 -
19" LCD FP PC monitor?
By majax79 in forum ComputerReplies: 12Last Post: 21st Oct 2007, 01:54
