Hi all.
I was given a box of old 8mm (?) movie reels. These were taking with a small movie camera back in the early seventies. They are old home movies, and I have been asked to eventually convert them to DVD.
Can someone recommend a way to convert these movies to VHS so I can then convert them to DVD? I have a VERY SMALL budget to do this, so I need low tech (or cheap tech).
Any help or suggestions would be greatly appreciated.
Thanks,
rudnicke
A friend of mine played his old video on a projector and set up his digital camcorder on a tripod to record it. Then dubbed in music, which covered up the projector noise. I'm not saying this is the greatest way, but I don't know if they make equipment to link to that old technology. It really didn't look that bad.
44E -
Check this link. The advice seems to be pretty good.
http://www.dvdhomevideoeditor.com/TUTORIAL_howto_trans_8mmfilm.htm
Good Luck!
Problems with my VHS/8mm/MiniDV to DVD project
By compgl in forum Capturing and VCRReplies: 6Last Post: 15th Jan 2010, 10:30 -
Newbie post - Recommendations for VHS-DVD Conversion.
By Mysticle31 in forum RestorationReplies: 20Last Post: 8th Jul 2008, 01:51 -
Capture 8mm/VHS > DV, recommendations for hardware
By nutshellml in forum Capturing and VCRReplies: 4Last Post: 21st Mar 2008, 22:07 -
newbie capturing, show me the way: 8mm/VHS > DV
By nutshellml in forum Newbie / General discussionsReplies: 1Last Post: 21st Mar 2008, 07:37 -
Recommendations for VHS to DVD capture
By Bullworth in forum Capturing and VCRReplies: 8Last Post: 17th Mar 2008, 15:52
