Okay i'm using Dvd it rightnow and I'm having a problem with it when i try to burn a disk i always get a disk that skips on my apex dvd player however i can save the image then burn it with dvd decryptor and it works fine is there some seting that i need to tweak in dvd it to make it play right on my apex player? It works on other players? And if I should use a different application please specify what i should use. I would like something that is pretty straight
forward
As I explained to another beginner...
There are 3 things you can have for doing video work.
Speed.
Quality.
Price.
You can only have ANY TWO.
Which ones do you want?Cheers, Jim
My DVDLab Guides -
Many possible variables.
First make sure your media is compatible with both your writer and player (under lists to the left).
Second make sure your DVD writer is supported by DVDiT (see Sonic site). This is most likely your problem. Check for updates.
Otherwise, do what you did. Save the image, then burn the DVD from an application that likes your writer. -
And by all means please try your disk that skips in your APEX on a different DVD player, please.
You said "It works on other players?"Originally Posted by moddenmania
The question mark made me think that was a question not a statement. If it does work on other players then the issues reduce to media issues with that player or other issues with that player.
You might get some clues reading comments for your model number under
https://www.videohelp.com/dvdplayers
http://www.epinions.com/
why can't I make dvd w several half hour shows dvd architect/sonic-
By rr1 in forum Newbie / General discussionsReplies: 5Last Post: 14th May 2011, 13:28 -
Sonic Vegas
By m baqar in forum Authoring (DVD)Replies: 9Last Post: 3rd Apr 2008, 05:29 -
Sonic Vegas
By m baqar in forum Authoring (DVD)Replies: 6Last Post: 3rd Apr 2008, 01:11 -
sonic vegas
By m baqar in forum Authoring (VCD/SVCD)Replies: 1Last Post: 2nd Apr 2008, 02:29 -
Sonic won't recognize DVD, computer does ...
By LittleQueenie in forum Newbie / General discussionsReplies: 2Last Post: 17th Oct 2007, 14:06
