    Dec 2003
    Dover , De.
    (forum descriptions are mind boggling......hope I'm in right place}
    I dont think size of file set is the problem , but here's what I've tried;
    1) VHS movie captured as mpeg2 file. Movie is 2:10 in
    length , so vobs etc amount to 11 gigabyte in size.
    (that was a surprise to me....) I then used VSO's
    DivXtoDVD app to transcode the mpg to vob,ifo,bup
    files.
    2) I tried DVDShrink , over and over, but I get error
    message , always the same, that a problem was
    encountered with "VTS_01_9.vob"
    3) I tried work-arounds, like renaming to .mpg , to
    see if that one file would run...and it DID, just
    fine!! It ran just that portion of the movie that
    it pertained to. So what was 'Shrinks problem with
    same file in .vob format??
    4) I tried substituting another 1gig .vob , renamed
    to match problem file, and 'Shrink still came up
    with same error message pointing to vts_01_9.vob.
    5) finally , I used the VOB Extras button ( not
    knowing what it's for) , and found option to "fix"
    vob structures and navigation . That took a while
    to do.....but , alas, was no help as far as
    DVDShrink problem was concerned.
    I had used the DivXtoDVD app on smaller mpg files
    and 'Shrink opened them with no error message.
    Any ideas??
    canada
    Split the mpg into 2 and put on 2 dvds,easier to shrink.
  3. Member GeorgeW's Avatar
    Feb 2005
    I don't know if this has anything to do with it, but if you are using a single-VTS Authoring application, then you might be limited to VTS_01_9.VOB -- you are allowed VTS_01_0 through VTS_01_9.
    George
    Apr 2004
    Miskatonic U
    Use a real encoder. 2:10 should be comfortable at around 6 GB. If you can, tighten up your capture to get closer in the first place. If you can't do that and maintain the framerate, then reencode with a proper mpeg2 encoder rather than using DivxtoDVD
    Read my blog here.
    Dec 2003
    Dover , De.
    ( a "real" encoder , or proper encoder....?? )
    Wondering what good this DivX2DVD app can serve?? if a 2 hr mpg file transcodes even close to 11 gig set of .vob etc. I'm not going to burn 2 DVD discs per VHS movie, and I dont think I could adjust the settings enough to create the smaller .mpg source file, nor would I want to since working from VHS standard to begin with.
    Even if 'Shrink could handle the 11 gig, would not the end product be seriously compressed in order to fit one DVD disc?
    Opinions...........
  6. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    That's your problem, right there. You should have set the encoding bitrate correctly to arrive at 4.3 GB instead. If you have the mpeg, why struggle with the VOBs? reJig can transcode mpeg down, but again, encoding to the correct bitrate to begin with is the better route.
    I really don't see why Shrink would choke, but then again, why should it accept 11+ GB DVD? After all, they don't exist.
    /Mats
