I'm creating DVD's with TMPGEnc DVD Author. I've found that when I create menus, they don't work properly on my standalone cheap DVD player (Magnasonic, can't find the model number).
I can skip forward chapter by chapter, and that works great with the chapters I defined ... but the normal tricks of using the menu, entering the chapter number and Enter, etc. don't work.
The menus do, however, work properly on my PC with PowerDVD.
Is this likely a problem with the cheap DVD player? Or is there some trick in TDA that I need to use?
I'm using the "Blue" template for menus in TDA, without altering the template.
Thanks!
menu problem in TMPGEnc DVD Author 3
By sanduul in forum Authoring (DVD)Replies: 13Last Post: 23rd Oct 2007, 20:20 -
TMPGEnc DVD Author 1.6 thumbnail menu issue
By Bix in forum Authoring (DVD)Replies: 0Last Post: 3rd Oct 2007, 11:00 -
TMPGEnc DVD Author 3 (MENU PROBLEM)
By jaffacaique in forum Authoring (DVD)Replies: 9Last Post: 18th Sep 2007, 20:43 -
TmpgEnc DVD Author 3 - Question About Menu Music
By heyjjjaded in forum Authoring (DVD)Replies: 10Last Post: 30th Jul 2007, 14:16 -
Menu troubleshoot using Tmpgenc Dvd Author
By tekka06 in forum Authoring (DVD)Replies: 8Last Post: 4th Jul 2007, 04:53
