Ok. I've been pissing around with this ofr hours and it's driving me nuts. I finally found a good setup to reencode a 2.35:1 DVD rip to 1.85:1 using AVISynth (2.5.5?) and TMPGEnc Xpress. The problem is the audio ends up insanely out of sync. I've messed around in TMPGEnc trying to get it to sync up and I can't get it no matter what I do. I had it to like -22000ms and it seemed dead on with the guy saying something, but then it seemed totally off the rest of that scene. Could the audio be not even playing at the right speed or something? I'm using the AVS as the video source and trying to encode with the AC3 as audio source, both demuxed with DVD Decryptor. I tried messing with audio stuff with avisynth and a converted WAV from the AC3 but that didn't seem to do anything either.
This is what I did with avisynth (working with Stargate Director's Cut U.S. release - 2.35:1):
LoadPlugin("C:\Program Files\AviSynth 2.5\plugins\MPEGDecoder.dll")
mpegsource("C:\STARGATE_ULTIMATE_EDITION\VIDEO_TS\ VTS_01_1.M2V")
LanczosResize(720,480,87,58,546,364)
I tried using dgmpegdec and cropping the video the same all around instead of using the avisynth script and it encoded in perfect sync, but the black bars aren't the same size on the top and bottom even though I cropped equally.
p.s. Someone should really put up a guide on properly resizing to other aspect ratios, like from 2.35:1 / 2.40:1 to 1.85:1 or even 1.77:1, etc. I've seen notihng on the site relating to that other than cropping all the way down to 1.33:1. That doesn't look very good without the ability to do true pan & scan. I found that LanczosResize thing on some obscure site with a Google search.
Results 1 to 1 of 1
AViSynth to display two video files in sync: specific requirements
By a1s2d3f4 in forum Newbie / General discussionsReplies: 19Last Post: 12th Nov 2010, 13:59 -
never mind, fixed audio sync problem in avisynth
By spiritgumm in forum Video ConversionReplies: 0Last Post: 16th May 2010, 11:58 -
Deinterlacing problems _ AviSynth
By pureimpure in forum Video ConversionReplies: 18Last Post: 15th Sep 2009, 21:25 -
Seeking audio sync using avisynth trim and selectRange
By Kab09 in forum Newbie / General discussionsReplies: 9Last Post: 27th Aug 2009, 13:10 -
Avisynth/TMPGEnc Xpress Audio Sync Issue
By Borflex in forum Video ConversionReplies: 4Last Post: 2nd Jun 2007, 15:10
