hi, i'm experimenting with quenc, hc, and several other mpeg2 encoders. since they all take avisynth scripts as input, i was curious what people find is the most efficient way of incorporating these encoders into a workflow that uses adobe premiere 6? do you just render an uncompressed copy of your movie and then launch the encoder? i've been trying to use the frameserver from debugmode.com to create a signpost avi, and then reference it in my avs file, but this seems to produce sketchy results (encoding works, but crashes premiere on completion). any suggestions?
thanks all!
steve
WMV encoders
By Gremlin78 in forum Newbie / General discussionsReplies: 1Last Post: 28th Mar 2012, 10:51 -
AC-3 encoders... which might actually work?
By takearushfan in forum AudioReplies: 5Last Post: 22nd Dec 2010, 20:54 -
windows 7 encoders?
By Browncoat in forum Newbie / General discussionsReplies: 5Last Post: 18th Oct 2009, 16:38 -
encoders?
By just in forum Newbie / General discussionsReplies: 7Last Post: 9th Dec 2008, 09:15 -
Spruce Encoders
By zerohash in forum Authoring (DVD)Replies: 1Last Post: 12th Sep 2007, 05:10
