ok, finally got my new pc with a dvd burner in it, and some nice software to go with it. While the dvdlab noobie guide was great ive got a few questions it cant realy answer. What im currently doing is looking to do is burn a a season of a show ive captured, and not sure of the best way of doing it. what i thought i could do would be to edit several shows into 2 or 3 dvd size movies, then use dvd lab to make chapters for a play by episode type menu. The main problem with this route is im not sure how to put in chapters by hand in files, just using the auto chapter wizard. so if anyone can explain that to me, or sugest a better way to tackel this project you have my thanks
Encoe each episode as a single movie. You should be able to get (if done right) 3 or 4 on each dvdr.
To manually set chapter points, click on the movie (Movie 1 for example) and in the preview window, browse to where you want the chapter point, then click this
I normally put 8 hours of TV rips per dvdr. No point in encoding at higher bitrate/quality.Cheers, Jim
My DVDLab Guides
Looking for advice on how best to start a project
By paulocon in forum DVD RippingReplies: 4Last Post: 6th Jul 2011, 05:19 -
Import Premier Pro 1.5 Project into Final Cut Pro/Studio 3 - how please?
By rjamesd05 in forum MacReplies: 1Last Post: 6th Sep 2010, 14:50 -
DVDLab Pro output Chapter problems
By ArtOfLosingMFZB in forum Newbie / General discussionsReplies: 4Last Post: 9th Mar 2009, 21:38 -
Setting the layer break on a DVD9 (DVDLab Pro project)
By lorix in forum Authoring (DVD)Replies: 4Last Post: 13th Nov 2008, 12:19 -
DVDLab Pro VMG and Menu Button and Chapter Skip on Remote
By raouliii in forum Authoring (DVD)Replies: 2Last Post: 20th Dec 2007, 14:08
