My encodes have been cooking at near 1X speed, but all of a sudden they are 4X slower. I'm running a defrag, but I'm curious if anyone elase has had this problem or might it be something deeper like a bad memory chip.
hmmm, could be hardware related.
I know I've made changes to motion-search settings trying to tweak my encoder which causes it to take longer. Did you happen to make any changes to templates or settings? What encoder? Are all other things still equal (source video type, no new hardware or software, etc...)?George -
xp sp2 recently?
I said I'll be done in a minute. I meant a Microsoft minute. -
If its your fragmentation level, please use PerfectDisk. it is the best defragmenter and there is a PDF file on the right side of the homepage that proves it.
I seriously doubt disc fragmentation would affect encoding time at all, much less quadruple it. The problem must be something else. AFAIK, encoding time is linear to processor speed.
/Mats -
Disc Fragmentation could slow down sligthy older, PATA HDs.
I wouldn't say that this is possible with latest Serial ATA or ATA 133 HDs
Check if DMA is still on...La Linea by Osvaldo Cavandoli
What is the source video format you are encoding from? For example, if it is AVI and the video is encoded in, say, DivX, did you update your DivX codec recently? Did you change the DivX codec settings recently? Have you tried encoding a different format AVI - like hufyuv?
A lot of processing time goes into decoding the source AVI file before the actual encoding can happen.
I have noticed that DivX 5.2 AVI files encoded with high motion search compression (bidirectional search and stuff) are slower to process compared to "old-fashioned" DivX 5.1 AVI.
Just a thought.The more I learn, the more I come to realize how little it is I know.
Playing smooth streaming fragmented mp4 without trex box
By adammw in forum Software PlayingReplies: 0Last Post: 29th Jul 2010, 03:01 -
ConvertxtoDVD encodes fine in past, now very slow
By brdhsby5 in forum Video ConversionReplies: 6Last Post: 10th Sep 2009, 14:51 -
Looking to do some test HiDef encodes
By wiseant in forum Video ConversionReplies: 5Last Post: 7th Jan 2009, 18:23 -
New PC - Encodes not as good...
By Browncoat in forum Newbie / General discussionsReplies: 28Last Post: 17th Jan 2008, 18:39 -
Can a fragmented ISO file cause playback glitches?
By xoADAMox in forum Newbie / General discussionsReplies: 3Last Post: 13th Nov 2007, 20:00
