Having noticed the percentage of buffer is only 0 to 2% when copy DVD files, is it just right? If no, is the buffer adjustable when copy the files with the DVD Decrypter?
The buffer should be low when just copying,if it was high then you would be using too much resources.The buffer should be high when burning.
I am talking about the ripping process with the DVD Decrypter. So the buffer is adjustable, correct? Do you know how to adjust the buffer, from the low to high or from the high to low? Thanks.Originally Posted by johns0
You cant adjust the buffer and there is no reason to adjust it.
URGENT: Any Blu-Ray players with adjustable audio delay / lip sync feature?
By psychotronicfilms in forum DVD & Blu-ray PlayersReplies: 4Last Post: 24th Feb 2011, 19:45 -
How to convert .vob files to a adjustable format?
By PurpleHaze22 in forum Video ConversionReplies: 24Last Post: 15th Nov 2010, 13:25 -
Searching adjustable audio recording level
By MegaDan in forum DVD & Blu-ray RecordersReplies: 0Last Post: 5th Nov 2010, 17:17 -
What is buffer size?
By dzsoul in forum Newbie / General discussionsReplies: 1Last Post: 6th Dec 2009, 09:04 -
Multi-Region DvD player, Volume Adjustable
By fitch.j in forum DVD & Blu-ray PlayersReplies: 0Last Post: 31st Aug 2009, 08:41
