When opening a video with VBR audio in VirtualDub you get a warning saying the audio might be skewed or something like that. You press OK and you're in. But when does this skew kick in? What I got to was that when processing audio using 'Full Processing' it will kick in. The warning says it won't happen if you decompress the audio to 'full size' but from what I can see it can only be done through 'Full Processing'.
So if the above makes an sense- will my decompressed audio, which is decompressed through 'Full Processing' - be skewed?
Thanx in advance!
Only if you save an intermediate avi.
If you frameserve after extracting full processed .wav, or use the video and extracted .wav to encode, it has no effect.Cheers, Jim
My DVDLab Guides
Need help with virtualdub error involving VBR encoding
By Hark in forum EditingReplies: 16Last Post: 12th Feb 2010, 00:45 -
Virtualdub has detected an improper VBR audio encoding
By lingoguysw5 in forum AudioReplies: 17Last Post: 26th Oct 2009, 11:12 -
VirtualDub 1.8.6 = Error about Audio (VBR) ??
By UmmAddan in forum Newbie / General discussionsReplies: 3Last Post: 28th Oct 2008, 11:55 -
KMPlayer, and use VirtualDub to edit AVI file, warning shows up
By rozaback in forum Newbie / General discussionsReplies: 5Last Post: 28th Apr 2008, 21:35 -
VirtualDub-MPEG Warning Improper Join?
By geewhiz in forum DVD RippingReplies: 2Last Post: 23rd Jun 2007, 08:10
- sounds good.
