hello!
I have these files from a movie:
VIDEO_TS.BUP VTS_01_0.BUP VIDEO_TS.IFO VTS_01_0.IFO VTS_01_0.VOB VTS_01_1.VOB VTS_01_2.VOB VTS_01_3.VOB VTS_01_4.VOB
what do I have to do next to creat a DVD disk and play it in my DVD player ?
thank you!
If you have Nero, you can drop those files into a Video DVD folder and burn. Don't worry about the audio folder, it stays empty. If it says they are non-compliant, then you may have a little more work to do.
Yep. Let me add that selecting "DVD Video" in Nero for the type of DVD will automatically create the necessary folder.
Click and drag the files from the right pane in Nero, into the VIDEO_TS folder in the left Nero compilation pane. Then burn 8) -
thank you!
I burned succesfully the dvd
I play it in the DVD player of the pc but there is no sound!
is there anything I can do ? -
You can download VLC media player and try playing the VOBs directly to see if the sound is OK there. The VOBs have the sound muxed (embedded) into them. Also, AVIcodec will tell you what type of video and sound are in the VOB.
The sound file may be missing or an odd type for it not to play. You can look to the left <<< under 'What is' DVD to see what audio formats are acceptable for DVDs.
There is also a chance that the audio has more than one channel and you need to select this with your DVD player. -
I tried to burn another set of such kind of files with Nero and it displayed this msg:
"The DVD-video files compliance test failed. The resulting DVD-video might be unplayable. Do you want to continue?"
what should I do please ?
thanks!
Need to make IFO, BUP for Single VOB
By Simmons in forum Authoring (DVD)Replies: 5Last Post: 28th Aug 2011, 21:15 -
How can I create IFO + BUP files for a VOB file?
By mac&me in forum MacReplies: 3Last Post: 4th Dec 2010, 03:06 -
Burn VOB without BUP IFO [Special]
By ron007 in forum Authoring (DVD)Replies: 1Last Post: 16th Feb 2009, 21:01 -
How to play a .vob .bup .ifo files?
By Kinstonian in forum Software PlayingReplies: 12Last Post: 19th Mar 2008, 17:26 -
VOB/BUP/IFO to AVI???
By chronic777 in forum DVD RippingReplies: 6Last Post: 11th Aug 2007, 13:10
