The captured .avi files take too much space, does it mean it also has the best quality? for archiving, what's the best way to keep the file size small yet the quality the same? if converted to .mpeg, can I get the same quality when editting in Premiere then export as .avi files?
Captured avi files are definately not good for archiving, they take up so much room cause capture codecs don't efficinetly use bitrate... they give the frames as much as is neccessary. If you want to edit first then keep them in the captured form till you export, but if you plan on storing them convert to a high bitrate mpeg first.
the definetly BEST Codec is DivX, if you want to use the Video-Files on your PC only.
But If your want to capture directly to DivX, you need a very fast machine! (Athlon >1,4Gig)
Join or Combine 2 AVI files with no quality loss.
By deadnuttz in forum EditingReplies: 18Last Post: 21st Sep 2016, 03:09 -
Multiple AVI files to multiple DVD discs, no quality loss, chapter per avi
By Delta007bhd in forum Video ConversionReplies: 11Last Post: 14th Apr 2010, 09:27 -
How To Produce High Quality WMV from AVI / DVD Files?
By devilcoelhodog in forum Video ConversionReplies: 3Last Post: 24th Jan 2010, 22:13 -
how do I convert .divx files to .avi without loss in quality
By Onceler2 in forum Video ConversionReplies: 2Last Post: 17th Oct 2009, 11:03 -
Quality problems after merging two .avi files
By Metallo in forum EditingReplies: 14Last Post: 13th Aug 2008, 10:50
