My drive is NTFS. Why it clip to that file size?Originally Posted by GeorgeW
Also I realize that the file size is exactly 15:00 of video.
This comes from the README file. I think this is the issue...automatic AVI splitting according to the timestamps on DV recordings
every video sequence can be saved into unique file -
yes, that makes sense. Your other post mentioned it splitting at 4gb (or I assumed the "4g" meant 4gb file size).
When I capture, I usually set it to break at the first scene after going over the 2gb mark. So your capture software is probably setup to break at the 15-min mark, or at the 3.xgb mark.George -
Under CONFIG, the "Capture From" tab, do you see "Max avi size (frames)"Originally Posted by vocalmind
If you were capturing PAL (25fps), then 15 minutes would be 25fpsx60x15=22500
So if that field has something like 22500 in it, your captures will be 15 minutes...George -
Exactly.
Thanks. Although I think about the computation of "max avi size". I still can't figure it out. My A/V basic is too bad.
Ill try it later and feedback the result then.
Cheers. -
Yes, thats right. I change it to 135000 for 1 hour and 30 min video.Originally Posted by GeorgeW
Thanks...
Should I use WinDV?
By tygger in forum Capturing and VCRReplies: 19Last Post: 6th Jan 2012, 18:23 -
Reducing filesize
By caper in forum Video ConversionReplies: 19Last Post: 7th Dec 2008, 20:22 -
WinDV
By kippard in forum Capturing and VCRReplies: 3Last Post: 8th Apr 2008, 00:43 -
Windv Scheduler
By ScottEslick in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 27th Jan 2008, 22:46 -
How to burn a 157 mins. video on a 120 mins. dvd
By Gerald Sr. in forum Authoring (DVD)Replies: 2Last Post: 20th Jan 2008, 03:19
