  1. Not sure of the best way to do this. I'd like to make a DVD from multiple AVI/Divx files I've downloaded. I saw the conversion section, it deals primarily with converting one file. I want the best way for putting multiple files onto 1 DVD, with a selectable menu.
    best way (my best way ):
    convert each to dvd mpeg with tmpgenc plus or mainconcept mpeg pro. calculate the bitrate with a bitrate calculator so all will fit on one dvd
    author all with tmpgenc dvd author or dvd-lab
    easy way:
    divxtodvd, diko, thefilmmachine. they all support multiplex divx files.
