Hi,
I try to copy 2 DVD title to one DVD using DVD shrink. The 2 titles are:
title 1: 10 min
title 2: 30 min
I put them in the orber, then "re-author" it. The resulted DVD is in a wrong order:
Master (title 2): 30 min
Extra(title 1): 10 min
It seems always put the longest title first as a master title, then short one second as extra. Does anyone know how to solve this problem?
Thanks,
Jean
DVD Shrink assumes the larger file is the main movie. What you are trying to do would prob be easier with an authoring program.
Google is your Friend
Separate multiple title DVD into single title DVDs
By Dogpoundz in forum DVD RippingReplies: 4Last Post: 24th Aug 2011, 19:49 -
Toshiba DVR620KU Makes title named Blank Title, when I finalize a disc.
By Dim29 in forum Newbie / General discussionsReplies: 7Last Post: 8th Jul 2010, 20:18 -
Can title menu have active multiple thumbnails using CXtoD (using 1 title)?
By bobbyg in forum Authoring (DVD)Replies: 1Last Post: 26th May 2010, 09:32 -
Field Order Problem?
By GordRocks in forum Authoring (DVD)Replies: 3Last Post: 4th Mar 2008, 09:19 -
DVD Lab - Movie/Title order in connections view
By BeachNut in forum Authoring (DVD)Replies: 5Last Post: 21st Jan 2008, 16:17
