ive just purchased a leadtek winfast tv2000 xp deluxe card.
i want to record onto dvd stuff that ive recorded using sky +.
i have an antenna connection goiing into the card.
what i need help with is what settings i should use to get the best capture in order for me to then be able to burn this to a dvd,
any help would be great
The steps are:
Capture - Edit - Filter - Encode - Author - burn
You need to do some reading.
A good generall reading could be this:
https://www.videohelp.com/guides.php?guideid=130&howtoselect=9;50#130
Later, ask again when is neededLa Linea by Osvaldo Cavandoli
thanks for the info
at the mo i was just using the winfast software & basic settings that it has.
ill try the guide you created as well - much appreciated.
does the software you mention allow you to capture in Mpeg4
Codecia DV best settings for capturing Hi-8
By magillagorilla in forum Capturing and VCRReplies: 2Last Post: 2nd Dec 2011, 18:18 -
best settings for capturing a VHS on VideoGlide?
By matt9b in forum Capturing and VCRReplies: 30Last Post: 4th Jun 2011, 15:01 -
Panasonic AG-1980 - what settings for capturing?
By justin81 in forum RestorationReplies: 1Last Post: 7th Oct 2010, 17:07 -
Capturing video... confused about some of the settings
By Cyber Akuma in forum Capturing and VCRReplies: 2Last Post: 20th Aug 2009, 11:05 -
how to understand what settings to use for capturing
By Fking in forum Newbie / General discussionsReplies: 6Last Post: 15th May 2008, 18:50
