Dear guys,
for now, I only have learned to add a logo in a video / film with the VirtualDub through its Frame server serving a *.VDR file to the TMPGEnc software, which creates two files, the *.M2V and *.WAV ones. The problem is that I am trying to Author a dvd with also a slide show option, and I haven't seen the TMPGEnc DVD Author capable to do so. And the others DVD Author softwares that I also have, and can do so, are not able to work with the *.M2V and *.WAV files at the same time. So, what I looking for now, is if that is a way that we can ceatre only a TMPGEnc file, I mean, a *.MPG,p.e., instead of the two ones above, or a DVD Authoring software that can hold the *.M2V and *.WAV files at the same time, and create DVDs with slide show options.
Sinc.,
Jose Julio
[beta] Bolide Slideshow Creator - Free AVI/MKV/WMV slideshow maker
By bolide in forum EditingReplies: 5Last Post: 30th May 2012, 04:18 -
DVD Authoring with Windows MM 2.6 OR AVS Authoring
By jagman in forum Authoring (DVD)Replies: 3Last Post: 8th Oct 2011, 05:41 -
DVD authoring ac3 out of sync after authoring but not before
By Genaugmen in forum Authoring (DVD)Replies: 1Last Post: 29th Jan 2010, 20:16 -
Great Article On Current BD Authoring Solutions & Future Mac Authoring
By videopoo in forum Authoring (Blu-ray)Replies: 1Last Post: 12th Dec 2008, 18:04 -
TMPGEncDVD authoring 3 with divx authoring
By buttzilla in forum Authoring (DVD)Replies: 0Last Post: 11th May 2007, 22:51
