I've installed the DIvx 4.11 codec. When I try to open a Divx movie in TMPgenc it tells me that this is an unknown video type?!!
I run WinXP by the way. Does anybody know how I can make the program see that this is a Divx or where the codec is installed?
Elmer
well,
maybe it is a Movie which is encoded with the DivX3.11 or s.th. else!
The newer 4.** ones, have probs with these files!
Install the 3.11 over the 4.11 again, it should work. (4.11 files are played with the 4.11 codec and 3.11 are played with the 3.11) -
Also sometimes the divx codec will rename all your divx movies so they have a .divx extension, change this back to avi and all should be well.
There is one simple thing you have to do.
Go to Options, Env.settings, VFAPI plug-in.
Increase the priority of 'AVI VFW compatibility Reader'.
Now you should be able to read divX.
Thnx Hardy3. That did the trick!
The rest of you, thank you very much for your replies as well!!
VirtualDub won't open divx movie
By shmish in forum Video ConversionReplies: 9Last Post: 15th Mar 2010, 08:54 -
avidemux won't open a DV .avi file
By BrianK in forum Video ConversionReplies: 2Last Post: 14th Jul 2009, 11:10 -
can't open file in TMPGEnc
By windranger in forum Newbie / General discussionsReplies: 12Last Post: 18th Feb 2009, 10:25 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 14:23 -
Nero won't open .mp4 file
By ChickaJane in forum Video ConversionReplies: 8Last Post: 22nd Aug 2007, 00:38
