My Seagate and WD drives were cooking in my PC - used a little app called DTEMP to get the temperature - they were both running at 41-42C. Mounted an extra 80mm fan in between them, blowing the heat out and away from the drives. Now, DTEMP reports 26C.![]()
http://private.peterlink.ru/tochinov/
nice program.
its only working for 2 of the 3 hard drives drives i have in this computer though..
my 200GB seagate ST32008822A is running at 104F/40C
my 40GB seageate ST340014A is running at 111F/44C
but my 30GB western digital isnt showing up..
I have 3 Maxtor 80GBs mounted together with a few mm clearance between. I just installed a new MB and hadn't hooked up the HD fan that is in front of the drives. I was amazed on how hot they got. Hooked up the fan and the surface temp dropped from about 60C to 35C. I'm sold on HD fans now.
Lumis - You might have to make sure the WD drive is set for S.M.A.R.T system monitoring in the bios of your system. Also, if your drive is hanging off of a third party PCI drive controller, DTEMP can't see it.
I dont really use a monitoring program for my hard drives. I have two drives:
Western Digital Raptor 74GB SATA
Seagate 160GB SATA
The two only have a couple of mm of space between them and the WD Raptor does get hot. However, I do have two 80mm fans in front of them in my Thermaltake XaserIII case for the cooling.
Rotate video by 180 degrees
By Anurag in forum Video ConversionReplies: 5Last Post: 7th Nov 2013, 22:09 -
Rotate portions of a video smoothly to different degrees
By froggo in forum EditingReplies: 7Last Post: 24th Nov 2009, 06:59 -
rotate video 90 degrees?
By cduval04 in forum EditingReplies: 6Last Post: 8th May 2008, 13:53 -
looking for software that will rotate video 90 degrees
By jimdagys in forum Newbie / General discussionsReplies: 32Last Post: 27th Mar 2008, 11:47 -
What credible degrees, diplomas or certification is there for videography
By wan2no in forum Newbie / General discussionsReplies: 4Last Post: 13th Mar 2008, 07:49
