  1. well I have about 10 gigs of video files and I would like to compress them for storage. Whats the best program to use and compression %
    riSky
  2. Whatever you use, I think you'll be mighty disappointed... most video is already compressed and you can't do much more with it. You may save a few megs (as in literally a few) per 700MB, and then you have to deal with waiting for the files to decompress... not an attractive option. Best thing is to buy a bigger hard drive (or store the stuff offline on DVDR).
  3. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Yes, as most video files are compressed to begin with, neither ZIP nor RAR nor any other lossless archive format will reduce the size much, if at all.
    /Mats
  4. Member lumis's Avatar
    Jan 2005
    the remnants of pangea
    i concur, video files are already compressed.. compressing them again wont compress them anymore, maybe a little bit..
    next...
    (p.s.- dont post multiple threads about the same thing, and post in the correct forum)
  5. Member steptoe's Avatar
    Why not just create and burn a data DVD, unless each file is over 4GB, you should only need 3 DVD's at most
  6. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    That was my first thought too, but then I went:
    "There are still those who don't have DVD writers - risky might be one of those..." But then I had a stroke of genius, and took a peek at riskys computer specs, and he/she's got a DVD writer...
    /Mats
  7. Member GeorgeW's Avatar
    Feb 2005
    The amount of compression you are going to see depends on the videos you are compressing. As mentioned, alot of videos will not gain much based on the codec used.
    But I have seen some videos compress by more than 50% -- it really depends on the codec used in the videos you are trying to archive.
    George
