  1. Hi, I love the Auto Layout feature, it makes things so quick. My probelm with the Auto Layout logic is I download TV episodes from TVtorrents and the naming convention is for each episode to be +1 from the last one. I understand why you use the logic as it is now, but I was wondering if you could put a preference Auto Layout option "each asset is a different titleset". This would make it perfect for quick adding of episodes. Thanks, James
    Also, now that there is automation with the autolayout, any thoughts about adding a command line option like c:\svcd2dvd c:\videos\*.avi would produce a dvd with one click or as a scheduled task.
  2. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    What do you mean?
    As for automation: batch processing & automation will be addressed after the "final" release.
  3. I'll download episodes of 24, for example, and the consistent file naming is
    24_04x8.avi
    24_04x9.avi
    24_04x10.avi
    24_04x11.avi
    I think having the option to be able to have each asset, therefore each episode, to have its own titleset would help with DVD navigation.
  4. hey Chrissy, just wanted to make sure you saw my clarification from earler... thanks, James
  5. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Yes i did. As those files have a common base name, to get a TitleSet per mpeg you would rename them or put them in unique folders. Or you could do it manually....
  6. Thanks for the reply. I thought i'd have to rename them, but an option/checkbox for titleset per asset would make the autolayout even easier. If you could add it I'm sure it would help alot of people who use this for multiple episodes. Thanks again for the great product! James
