Okay, I am brand spanking new here and to video capturing and I have a lot to learn. I hope that this is the place for it.![]()
Currently, I have an old USB Dazzle DVC and it worked okay under Win98SE. I have upgraded my OS to WinXP Home and this thing doesn't work so I am looking for a new capture device. My system has an AMD Athlon XP 2200+, 256MB RAM with a 40GB HD and a new 120GB HD on the way.
My first question is about what type of new device I should get. Should it be USB 2.0 or PCI? Which is faster at capturing?
From what I have been able to learn so far, I think I need/want to be able to capture in .avi format. My main goal is to convert home VHS to DVD after editing them without spending a fortune on the capture device. Whatever device I buy has to have analog (RCA) inputs as my camcorder (Panasonic Palmcorder Model PV-L352D) is not set up for S-video.
What would the experts here recommend for a good starting device that is in the $50 range that will capture in .avi format? I have looked at the reviews here and there does not seem to be any kind of definitive recommendations. It seems that all the devices create problems for some. I am hoping to avoid this and get a decent device from the start.
I would appreciate any and all help/input/suggestions/recommendations.
Thanks,
Vance
Seems like you have described what you want. It looks like a PCI or AGP capture card with composite in. PCI would be if you want to keep your present AGP card. For AVI capture for `$50US, I would check out a used ATI card from someplace like E-Bay.
PCI will be much faster than a USB solution. USB is OK for direct to MPEG with low quality, probably similar to your dazzle box. AVI capture is best with a card. For the price you quote, the older ATI cards are a great value, with very good capture quality. Check Lord Smurfs site for capturing and ATI info: digitalfaq.com
PS3, HDMI Splitter, Video Capture Device or Card, Ambilight, ADVICE!
By NexusSIX1976 in forum Capturing and VCRReplies: 5Last Post: 16th Oct 2011, 21:38 -
Advice on a direct capture device from MiniDV cam.
By nomeite in forum Capturing and VCRReplies: 5Last Post: 29th Oct 2010, 10:43 -
Need advice, looking for a USB Tuner/Capture Device that will work in OS X
By jrru2 in forum Capturing and VCRReplies: 2Last Post: 23rd Oct 2010, 20:06 -
Need also expert advice about video and sound files!!
By vantechmag in forum EditingReplies: 8Last Post: 14th May 2009, 11:48 -
Need Capture Device recommendation advice!
By unclekracker in forum Capturing and VCRReplies: 4Last Post: 2nd Apr 2008, 12:54
