    Jan 2004
    I have PowerDVD installed and can play Mpeg2 in Media player. I can't seem to get them to work in Powerpoint (2000)...It just shows a black screen and doesn't really do anything when you push play...or would a newer version of PP do it?
    Or do I have to convert to MPEG1? or AVI
    Thanks in advance
  2. Banned
    Jun 2005
    Piter
    Hi bhbuckeye!
    You can convert your ppt file into avi using this program:
    http://www.geovid.com/Presentation_to_Video_Converter/
    You are in breach of the forum rules and are being issued with a formal warning.
    Just an Alias of Argonavt. No Avertising.
    / Moderator bugster
  3. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Do you mean that you are putting an MPEG-2 file inside your Powerpoint presentation and are trying to get it to play "inside" the presentation ?
    That's how I read it anyway ...
    MPEG-1 should definitely work.
    If in doubt, Google it.
    Mar 2006
    China
    I think your OS is XP, on win2000/xp system, the merit value of MPEG2 Splitter is lower than MPEG2 Demultiplex, that is the main reason of why mpeg-2 cann't play back perfectly.
    Here is a document and give a method to fix it.
    http://www.easympeg.com/phpBB/viewtopic.php?t=5
