  1. This is basically a continueation of my last thread("Audio selection in DVD-Lab"). I have a Menu with buttons 'Japanese' and 'English'. Jap is set to "Set Audio 2" and Eng is set to "Set Audio 1". During testing i select Japanese but it never loads the Audio stream, however the English stream(Audio 1) works flawlessly.
    Heres the setup:
    http://img240.exs.cx/img240/1678/setupmovie6nw.jpg
    http://img240.exs.cx/img240/9307/setupmenu3bi.jpg
    Any help would be greatly appreciated
  2. Member GeorgeW's Avatar
    Feb 2005
    I noticed your audio streams are not the same length -- could that have anything to do with the problem?
    George
  3. I doubt it, its only a 5 second diffrence. Thanks
  4. Member GeorgeW's Avatar
    Feb 2005
    And both of them are 4 minutes longer than the movie?
    Did you apply the DLP Updates? One of the updates lists this item:
    Missing audio in last VTS movie may set no audio for whole VTS
    George
  5. No i didn't apply any updates. None that i know of at least. Il check it out thou. Thanks
