Does anyone know if there are any other programs similar to Kprobe that will scanning and test DVD media? I am looking to test the media for errors before burning. Kprobe only works on Lite-On DVD and CD Drives. Thanks in advance.
Results 1 to 9 of 9
Keep in mind you still need a drive that supports PI/PIF scanning. None of these programs will work with Pioneer or NEC.
Still a few bugs in the system... -
Originally Posted by chas0039
You best bet is to buy a cheap Lite-On DVD burner for reading burned DVDs and use KProbe for scanning, though. That seems to be the standard approach that most people have taken. -
Originally Posted by jabloomf1230Still a few bugs in the system...
Although DVDInfoPro DOES do PI/PO testing with Pioneer drives now, the Pioneer burners are not considered very accurate or reliable for doing such tests. Nero CD-DVD Speed's author was requested by Pioneer NOT to enable PI/PO testing with their drives by Nero CD-DVD Speed, that's why it doesn't support it.
I would suggest the BenQ 1620 (or a clone) instead of a Liteon for testing. The BenQ 1620 is an outstanding burner and has very good media testing support including a utility called QScan which does non-destructive quality testing of blank media. It sets book type automatically and will burn a lot of 8x media at 12x or faster.
It is also supported by CD-DVD Speed and DVDInfo for PI/PIF error testing. It is also a very good value. NewEgg has the BenQ 1620 starting at $54 with free shipping.
Software Similar To ConverXDVD
By niteghost in forum Authoring (DVD)Replies: 3Last Post: 30th Jan 2012, 15:11 -
Problem capturing audio with most programs, any fixes? + Lagless programs?
By fgsfdsyo in forum Capturing and VCRReplies: 5Last Post: 15th Oct 2009, 16:51 -
is lg ggwh20l and kprobe compatible ?
By deejay.2001 in forum DVD & Blu-ray WritersReplies: 8Last Post: 4th Sep 2009, 01:41 -
4:3 to Letterbox (or Something Similar)
By christopheramos in forum Authoring (DVD)Replies: 2Last Post: 23rd Aug 2008, 02:57 -
ffmpegX and similar converters
By febras1982 in forum Authoring (DVD)Replies: 0Last Post: 27th Nov 2007, 10:02
