  1. hi guys
    can any1 help me
    i have burned a couple of Photo'son cd with Nero just standard VCD
    I just drag and drop the pictures and Nero accepted them
    it works great i can watch it on my stand alone DVD
    but now the files are in the dir SEGMENT in the cd and it's a .DAT file
    how do i watch them on my computer??
    and how do i convert it into a .jpg file again
    thanks in advance
  2. When creating the CD menu in nero , there is an entry to allow storing the images in a CD directory "Pictures". Your images will be stored there in the source format.
    A second choice is to watch it on the PC using a DVD program such as WinDVD.
    Dec 2001
    Richmond Va
    Hold down the shift key and right ckick on the.DAT file . Open with Windows Media player. It should run fine
  4. curious2know it's not a cd menu it's just a few pic of my holiday
    i'll try windvd out but actully how do i convert it to the old format .jpg i want to send them
    and tbear263 i allready tried that but it doesn't work
  5. hmm windvd doesn't work either
    and i think nobody here know how to do this
    well i think it's now only playble on my dvd
    well thanks anyway dudes
  6. VCDGear can extract .DAT from VCD back to .MPG so it may be worth a try. Not sure if it will enable you to go back to original .JPG images though.
