Hello,
I thought this would be a simple project but...
I'm trying to import clips from a friend who sends them to me on DVDs.
Each disc has about 6 .avi files on it. The quality is excellent. He says they are full capture video. When I import the clips into iMovie4 and 'share' in various settings the quality goes way down. I've heard this is because iMovie 4 converts everything to DV streams.
Not sure about this. What do I have to do or purchase to keep the quality the same as the original footage?
Any help with this is greatly appreciated.
Thanks,
Al
Then get him to send you the DV files or the tape(s). That IS the "best quality"Originally Posted by pizzapizzaKeeper of the "Unofficial" iMovie FAQ also for the lastest iMovie news click here
Your source for iMovie answers and what not! ;-) -
Hi and thanks for the reply,
He was sending me the full DV but he lives in the UK
and have just found out that it is PAL. My computer was set for NTSC.
I've changed that preference and have made a lot of progress with the quaity. I now need to tweak the settings within iMove 4 to make it look very good.
I just purchased Sorenson Squeeze 4 Compression Suite for the final encoding. This should make for a much better overall finished product.
Thanks again and take care,
Al -
My boy Lennat is the PAL to NTSC master and wrote this up. Not sure if it helps you going from 25 to 30 FPS.Originally Posted by pizzapizza
http://www.danslagle.com/mac/iMovie/tips_tricks/6017.shtmlKeeper of the "Unofficial" iMovie FAQ also for the lastest iMovie news click here
Best way to import .mts files to iMovie?
By S4Shredr in forum MacReplies: 4Last Post: 22nd Jul 2011, 13:45 -
Import via AVDC-55 to imovie '09, audio has vanished.
By sackreiter in forum MacReplies: 4Last Post: 25th Dec 2010, 12:54 -
easiest way to import footage from DVD to iMovie?
By cinclodes in forum MacReplies: 3Last Post: 27th Oct 2010, 10:07 -
Canon ZR50 to imovie import
By tlcohn in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 16Last Post: 18th May 2010, 11:03 -
MPEG-2 video/audio to MP4 or anything iMovie will import
By quella in forum MacReplies: 9Last Post: 3rd Dec 2007, 19:07
