When I click begin output it exits and I lost all my work!
I use version 1.5.20.62
thks for your replies!!!
I'm not sure if anyone can answer this one, but it would be of great help. I'm having the same problem. I've tries 1.6 and 1.5 to no avail
Save the project before you click 'begin output'. Then you won't lose all your work.
I solved days ago..sorry I forgot to post.
Simply had a corrupted file in the program directory... -
What file was that?
It's not so much a problem of using my work. I have saved the project but everytime I try to output it, the program closes out and nothing happens.
TMPGEnc Dvd author 3 problem
By prcole18 in forum Authoring (DVD)Replies: 7Last Post: 7th Oct 2008, 12:33 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 03:41 -
menu problem in TMPGEnc DVD Author 3
By sanduul in forum Authoring (DVD)Replies: 13Last Post: 23rd Oct 2007, 20:20 -
TMPGEnc DVD Author 3 - Playback problem, Help!
By cbales_24 in forum Authoring (DVD)Replies: 2Last Post: 18th Oct 2007, 17:29 -
TMPGEnc DVD Author 3 (MENU PROBLEM)
By jaffacaique in forum Authoring (DVD)Replies: 9Last Post: 18th Sep 2007, 20:43
