When using NeroBurner - if the verify option had been left set when I last directly used Nero does a write through NeroBurner verlfy?
Malcolm
No. NeroBurner just uses the Nero API. From a settings point of view it is independent. Would you like there to be a verify option?
Yes please. If it is not a lot of work.
For the sake of an extra 10/15minutes it is very useful in detecting failing RW's - and also bad writes/media before you start swearing when it stops at that seat grabbing moment in the middle of the movie.!
Malcolm -
I have added it. It will be in the next release.
Hi ChrissyBoy,
In addition to the verify is it possible to add record speed ? I have x12 writer and NeroBurner always goes for the max which makes the disks not play in standalone player.
Thanks muchly
I have a build with this in. Email me if you would like to test it.Originally Posted by AnAsTaCiA
CBSVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Sorry CB, I would have mailed you but been away for a few days (lucky me huh).
Anyway, I see you have incorporated this into RC7.
Many thanks. You're a star!!!
Before you know it you'll be as well known as me lol
Nero 8 not recognizing DVD burner
By JCWBobC in forum Authoring (DVD)Replies: 11Last Post: 14th Dec 2009, 23:20 -
Question re updating to latest version svcd2dvd
By Lord Flange in forum SVCD2DVD & VOB2MPGReplies: 7Last Post: 11th Oct 2007, 19:04 -
Question about new DVD-burner
By Videonator in forum DVD & Blu-ray WritersReplies: 8Last Post: 7th Oct 2007, 05:39 -
Just another DVD burner question...
By newbie3 in forum DVD & Blu-ray WritersReplies: 1Last Post: 3rd Sep 2007, 20:47 -
Nero Burner in new version of s2d version5
By couzican in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 3rd Jul 2007, 19:50
