I have Medion8080xl with Medion (7134)WDM capture card
Using "capture" PowerDirector it failed to initialized at 70% and crashed
Cyberlink said it should work with all WDM card and suggested to uninstall
all editing software and reinstall PDwhich I did and it still crashed
Medion service said it should work after updating the driver which I did and it still didnot work and crashed
Hi Rudy,
i have the same Problem (it's also with Powerdirector3). I did update the driver for the Medion cad, with no succes. I ask the medion support, they said that's not our problem, we sell the Computer (MD 8008) with power director2, and it works.
I ask the cyberlink support because i like to update my powerdirector2 to version 4. They said, look at the list of supported cards. We dit not support cards with the 7134 Chip set. I say, at your website you say we support all cards with WDM Driver. And, now i'm still waiting for the answer of this - I'm waiting for two months now!!! But they send me an offer for my update with a lower price???
I hope any other user can help us.
Kasimir -
Hi together,
now Cyberlink Power Director 5 is out, an this version works fine with the Medion TV Card. -
Kasimir,
How good are the caps? The caps from the Power Director that came with my Medion 8084MD were very bad. -
Originally Posted by geowharton
i think the caps from Power Director 5 are nice. My Medion 8008MD came with Power Director 2.5, and with this version the caps have lots of A/V sync problems. The only thing i'm missing with PD5 is a list with the names of the stored TV-Chanels.
Looking for capture device, is this what I need?
By V Bot in forum Capturing and VCRReplies: 3Last Post: 21st Apr 2012, 09:16 -
Capture device
By ingeborgdot in forum Capturing and VCRReplies: 7Last Post: 11th Sep 2011, 20:02 -
Looking for new driver for video card- MEDION (7134) WDM Video Capture card
By 2prfm.com in forum Capturing and VCRReplies: 3Last Post: 15th Sep 2008, 02:48 -
Capture device needed for old VHS or 8mm camcorder capture....What to get?
By thor911 in forum Capturing and VCRReplies: 11Last Post: 5th Oct 2007, 04:31 -
capture device for hd
By jjjamiem in forum Newbie / General discussionsReplies: 2Last Post: 8th Aug 2007, 14:30
