Is it ok if while encoding DV to DVD or VCD using TMPGEnc you still play with your PC?
Because while im encoding I still can do other stuff. Not sure though if it has an effect on the result.
Maybe you can share your experience...Thanks
the only effect it will have on your file is that it will take longer to encode. other than that, nothing will change
Some people are only alive because it may be illegal to kill them -
Thats good to hear. I thought things like bad image, etc...will happen.
Thanks. -
I guess you can still try and play with your pc but usually it will take up 100% of the CPU (unless you have a P4 where it seems to take up 50%) Although I have found I can stream DV from TV and encode to DVD at the same time (using an external DV encoder)
Originally Posted by vocalmind
It takes data from a file, works on it, and then puts it in another file.
If your operating system can't hand that while allowing other application to run, you've got real problems.
Originally Posted by siccoyote
Doing something else whilst actually encoding is fine. If you are captureing or transferring DV via firewire, you may get dropped frames due to processor and disk load. If you are burning, disk activity can starve the burner of data and cause bad burns.
There are 10 kinds of people in this world. Those that understand binary... -
you should NEVER do anything with your computer whilst it's processing video files. if you do, evil Loa will possess your IRQ numbers. it's true i've seen it.
never absorb anything bigger than your own head
TMPGENC encoding problem
By whschlebaum in forum Video ConversionReplies: 0Last Post: 26th Apr 2011, 22:22 -
TMPGEnc Author Keeps Re-encoding
By lostinspace00 in forum Authoring (DVD)Replies: 13Last Post: 8th Apr 2011, 08:16 -
Encoding using TMPGenc 4.0 Xpress
By abdul_sma in forum Video ConversionReplies: 1Last Post: 19th Jun 2010, 07:15 -
TMPGEnc Plus Encoding
By crys94 in forum Video ConversionReplies: 9Last Post: 29th May 2008, 22:23 -
TmpgEnc 3 - stop it from encoding 544x576 ?
By katykaty in forum Authoring (DVD)Replies: 3Last Post: 10th May 2007, 17:06
