  1. For some reason, XP is not showing icons for my JPEG and BMP images. Is there any way I can fix this?
    This is a JPEG image, but there is no icon:
  2. Member Faustus's Avatar
    Apr 2002
    Dallas, TX
    What program is it associated with? Try reapplying that association.
    If mean the icon is no longer a thumbnail then check what view your in.
  3. Member glockjs's Avatar
    Feb 2004
    the freakin desert
    open up a file explorer screen...say double click on my computer....>tools>folder options>files types....
    all the file extensions will show there. look for the extensions that you're having probs with...say JPG for example..."Opens with" should be windows picture and fax viewer...and if changing that doesnt help click on advanced and you can change the icon.
    im guessin u uninstalled a proggy that took over those file types?
    good luck
    PhenII 955@3.74 - GA-790XTA-UD4 AM3 - 2x4 Corsair Vengeance@1600 - Radeon 5770 - Corsair 550VX - OCZ Agility 3 90GB WD BLACK 1TB - LiteOn 24x - Win 8 Preview - Logi G110+G500
  4. Originally Posted by glockjs
    Thanks! That worked perfectly
  5. Member glockjs's Avatar
    Feb 2004
    the freakin desert
    np
