  1. I have read everything I can find about this DVD drive and still I can not figure out why it is having problems. Here is a typical log file from a failed attempt using DVD X Copy Plat 3.2.1. Since I have not been able to copy a fully compressed movie, in this example I tried to only copy part of the movie. Any help or recommendations would be greatly appreciated. BTW I am using TDK DVD media appropriate to the drive speed. What happens everytime is that the DVD begins to copy and then anywhere from a couple minutes to 10 minutes pass before it fails.:
    DVDXCopy Platinum 3.2.1
    __________________________________________________ ___________
    Build Date : Oct 28 2003 15:29:02
    Current Date: Sat 2-12-2005 1:40:3 PM
    Windows Version: 5.1
    DLL Versions:
    asyncflt.dll 3.10
    bouducon.dll 1.2.1.83
    english.dll 1.0.0.0
    platinum.exe NOT FOUND!
    resdll.dll 1.0.0.1
    vso_hwe.dll 1.3.6.98
    xpress.exe NOT FOUND!
    __________________________________________________ ___________________
    Setting up resource for DVDAPI
    Loading Resource
    Selected Drive : 1:0:0 - TDK DVDRW0404N 1.0C [D]
    (Ide)
    Using Selected Drive: 1:0:0 - TDK DVDRW0404N 1.0C [D]
    (Ide)
    Using Selected Drive Index: 0
    Generating Compression Settings for 1 titlesets.
    Total Sectors: 2264220 Overall Compression Pct: 100
    Titleset 1: 100 % Size: 2264220
    Compressed Titleset 1: 100 % Size: 2264220
    (4,637,122,560)
    Total Compressed Sectors: 2264220 (4,637,122,560)
    -- Single Disc No Compression --
    >>> Titleset Compression 1: Size: 2264220
    (4,637,122,560)
    Done Reading..
    Load burn engine.
    0040B4F0: New BLANK or ERASABLE DVD media has been
    inserted - progress is the media change count,
    starting from 1:
    Writing Disc: Monsters
    0040B4F0: Gathering file from the path passed
    0040B4F0: Generating image and cache
    0040B4F0: Writing Movie:0
    0040B4F0: Writing Movie:125
    0040B4F0: Writing Movie:138
    0040B4F0: Finished.
    0040B4F0: Writing failed (write error or process
    aborted):
    0040B4F0: Drive is not ready
    0040B4F0: Blank media has been removed
  2. Before puting the blame on the burner, I'd drop the crappy DVDXCopy software and make a backup using DVD Shrink, have it output as an ISO image, then burn the ISO with DVD Decrypter. Both programs are free, VERY stable and reliable, and are superior to DVDXCopy anyway.
    P.S. - your error message says right there that it's not 'finding' two of the main EXE programs, which is obviously a problem. If you still insist on using DVDXCopy (don't :P ), uninstall then reinstall it.
  3. I agee with Steve,your process is totally fcuk up...
  4. Originally Posted by saintbebo
    I don't know your burner, but I read it can write to DVD+/-R @4x, to DVD+RW @2.4x and to DVD-RW @2x speed.
    Which exact TDK DVD media are you using? If it is 1-4x DVD-RW, then it could be a compatibility problem. The 1-4x DVD-RW media (Version 1.2) are not backward compatible to 1-2x DVD-RW (Version 1.1) media and cannot been recognized by older burner models with old firmware.
