I just bought a Linksys wireless router and I am having weird troubles with it. This happens both wirelessly and wired, with my laptop running XP SP2 I cannot connect to the internet for more than 5-10 mins a day. It works at first and then I keep getting timeouts. I am still connected, I can ping and receive the pings back, I can use AIM, check email and so on. Just the internet fails.
My PC is also connected to it through ethernet cable and it works perfectly with it. This is getting weird, it works fine surfing the net at school wirelessly. Just not here.
Is there anyway Windows XP and this thing are just not getting along over the web? Can I change the ports in mozilla and IE to try a different one? This is my first dealing with a router so I am a bit confused about it.
Thank you guys, you have been VERY helpful to me in the recent weeks![]()
A bird in the hand is worth a foot in the tush-Kelly Bundy
I have exactly the same problem. WWW fails but emule, skype MSN still work. I have to repair the connection and the internet is back on.Originally Posted by devinemi83
edit -
Here's my thread
Buddha says that, while he may show you the way, only you can truly save yourself, proving once and for all that he's a lazy, fat bastard. -
I found the answer, the VPN client that the school requires us to run to access their network somehow was blocking my own http access on MY network. I simply turned on the VPN client and *bang* ir worked.
This is so whacked out.
But I am so bookmarking this thread because I get the feeling me and this router are gonna have more troubles with each other. LOL
DVDStyler weird problem
By xeroblast in forum Authoring (DVD)Replies: 0Last Post: 8th Sep 2011, 01:37 -
weird computer problem
By lordhutt in forum ComputerReplies: 5Last Post: 1st Dec 2009, 15:45 -
Linksys WRT54GX4 router problem
By SIRCOOKS in forum ComputerReplies: 9Last Post: 19th Feb 2008, 10:40 -
Can a router/wireless router shut down computer?
By tmh in forum ComputerReplies: 7Last Post: 29th Jan 2008, 12:34 -
Connection problem with Asus router
By tweedledee in forum ComputerReplies: 23Last Post: 3rd Sep 2007, 22:07
