Can someone tell me (or refer me to a guide) on how to extract the audio from a concert DVD to burn onto a PCM audio CD.
I have used DVD2AVI, but the result are always very 'dull and muddy' compared to the origional, even when I have ripped the Linier PCM audio track.
Any help would would be appreciated, including programs I should be using.
thanx,
ash
Hi!!!!111
Try to use vob to mp3 converter...
you will find it.
on doom9
http://www.doom9.org/Soft21/Files/Audio/VOBtoMP3v0.7.zip -
then you can burn it with nero or another burning toool that support mp3 to audio cd burning
then u can download the latest
AzidLameGUI
that is a GUI for vob to mp3
U find all there -
Thanx MoZo...
....I would prefer to avoid encoding to MP3 first as I would be reducing my frequency range quite considerably.
Any other suggestions that don;t involve compression? -
The AZID/Lame GUI will also go straight to wav or MP2, does all your frequency conversions and boosting aswell.
Why dont you try vob2audio it can rip ac3 files wave files or mp3 if you wanted it
download it here:
How to mux a m2v file with 44.1khz, 16-bit wav?
By seven_deuce offsuit in forum Newbie / General discussionsReplies: 2Last Post: 24th Apr 2011, 22:25 -
Want To Mux MPEG-2 Video With .WAV to Create .VOB
By judicata in forum Newbie / General discussionsReplies: 2Last Post: 12th May 2010, 16:07 -
How to convert .vob to .wav?
By showmi in forum Newbie / General discussionsReplies: 2Last Post: 14th Jul 2008, 12:27 -
VOB to wav & m2v and back to VOB
By GordRocks in forum Video ConversionReplies: 2Last Post: 13th Jan 2008, 05:44 -
Nero Recode and 44.1kHz audio
By rindless in forum Portable VideoReplies: 2Last Post: 6th May 2007, 14:16
