I have a few DVDs that have a combined birate of over 9800kb/s. Therefore, none of them would play properly in my DVD player.
Is there a way to re-encode the DVDs at a lower bit rate? I do not want to encode to mpegs, and then back to DVDs.
THanks
Ming
DVD Shrink doesn't seem to really re-encode the DVD for me. No Matter what setting I put it onto, it finishes in 5 minutes. Also, the bit rate is still too high after using DVDShrink.Originally Posted by waheed
I didn't try CCE because it requires money, but I did use QUenc and the finished files have an acceptable bit rate. However, when I burn the movie with my BENQ 1610 at 4x onto a Sony DVD-R and a Benq DVD+R using Nero and TMPGENC DVD Author 1.6's DVD writing software, the video still freezes randomly.Originally Posted by guns1inger
It should not be a problem with the burner or the media because I have plenty of Benq DVD backups, and they play fine in my KOSS dvd player.
Do you know anything that could be causing this weird problem??
THanks
Ming
PS...Transfer speed test shows a PERFECTLY smooth speed curve, so the burn quality is good. The discs work fine in my computer. -
Tried again today with a Verbtaim DVD-R, same problem.
I'm sick and tired of dealing with all this, I may just use my laptop as my playback tool. Or I may even build a HTPC
The correct way to crop and encode anamorphic DVDs?
By harbourshin in forum Newbie / General discussionsReplies: 0Last Post: 13th Feb 2011, 21:32 -
DVD Rom can burn DVDs but won't recognize burnt DVDs.
By soonie in forum DVD RippingReplies: 0Last Post: 23rd Aug 2009, 16:03 -
What software are you using to rip/encode DVDs?
By dbone1 in forum Video ConversionReplies: 2Last Post: 21st Jun 2008, 01:39 -
Audio synch problem using MTR and ffmpegx to rip DVDs and encode for ipod
By becky_s in forum ffmpegX general discussionReplies: 1Last Post: 2nd Nov 2007, 01:15 -
I want software that copies DVDs and transfers torrents to playable DVDs!
By maccaneer in forum MacReplies: 14Last Post: 28th May 2007, 09:02
