for my mass media class, we were given an assignment to do some research on a TV show of our choice. we can make a 5 min "best of" video of our show where we take really good stuff and put it into the video. I want to take clips from the complete first season of Reno 911! that I have on dvd. How would I go about doing this? Is there any way to put it to VHS? VCD or SVCD is fine too. however, I don't have a DVD-ROM drive or anything like that. I have a miniDV camcorder but thats about it. any suggestions?
Hi ArtOfLosingMFZB,
1. Rip the DVD files to your hard drive using either DVDDecrypter or Smart Ripper (if the former doesn't work).
2. Isolate the individual clips using DVDShrink (at 100%, so no quality loss). This will produce VOBs for each clip.
3. Author the VOBs to a finished product. There are free authoring tools that will suffice for this.
4. You may be able to use DVD2VCD on the VOBs to get your (S)VCD. To get to VHS, just play the (S)VCD in your DVD player and record to tape.
There are plent of guides to provide detail on the steps above. And the tools are fairly intuitive, so have a stab at it.
Good luck.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
Rip to hard drive with DVD Shrink (Free).
Pull out clips as mpgs with VideoReDo (Free Trial)
Looking for software to select 10 min clip from DVD
By jimdagys in forum EditingReplies: 3Last Post: 17th Apr 2009, 08:20 -
Compile VCD movies plus subtitle into one DVD
By GeekyChocolate in forum Newbie / General discussionsReplies: 5Last Post: 26th Feb 2009, 07:14 -
Noob here, Compile Dvd problem!
By dbgt in forum Authoring (DVD)Replies: 3Last Post: 8th May 2008, 18:08 -
Do I need to stop clip analysis in order to export clip for dvd
By maevek1 in forum MacReplies: 0Last Post: 9th Apr 2008, 08:26 -
DVD-lab pro compile problem
By Sats in forum Authoring (DVD)Replies: 8Last Post: 11th Sep 2007, 15:13
