Here is my question..
I did a short clip in Premiere Pro(about 1min.).In the end of the clip I'll have menu buttons fade in.
Can I do something like that in DVD Lab.Or I have to use just still images??
Here take a Look at this I'm not sure if you can use a Video file as the Button though,
http://www.mediachance.com/dvdlab/Helppro/motioncell.htm -
You can use anything on a menu as a link/button, by using a hotspot over it, or an invisible frame, or invisible shape of any sort.
Turn off the mapping colors (sliders all the way left, if you want it invisible completely.Cheers, Jim
My DVDLab Guides -
You can use a motion menu with delayed buttons in DVD-Lab. The only problem, is that the activating buttons won't be visable until selected when using a video for background.
You can use the motion menu you created in premiere. Import it into DVD-Lab as menu. You can use objects in dvd-lab (such as arrows) to point to the buttons you created. You can set them to become active when your buttons fade in. You can also set it up to loop begining when the buttons are visible. I've done a few of these and it works quite nicely, though it takes a little more effort to make them. -
This is available in DVD LabPro, but I don't think you can do it in DVD Lab
George
DVD Lab Pro Menu Resolutions
By Anonymous344 in forum Authoring (DVD)Replies: 0Last Post: 6th Dec 2010, 17:11 -
DVD Lab Pro menu help
By stantheman1976 in forum Authoring (DVD)Replies: 12Last Post: 27th Jan 2009, 17:27 -
DVD-Lab pro menu problem
By wackman in forum Authoring (DVD)Replies: 4Last Post: 26th Aug 2008, 04:52 -
Motion Menu on dvd lab pro 2
By djakaburo in forum Authoring (DVD)Replies: 1Last Post: 12th Apr 2008, 12:03 -
DVD Lab Pro Menu Troubles
By Freestyler223 in forum Authoring (DVD)Replies: 5Last Post: 21st Dec 2007, 23:30
