Just been reading this forum for a few days now and learning a lot. One of the programes people seem to love is Dvdshrink so iv just picked up a copy.
Seems self explantray peace of software, but one question i notice the quality setting how much quality do u loose say if i put it to the lowest of 34% WOULD that be bad quality what general quality settings used?
34% would be bad quality. Generaly, going under 70% will result in some quality loss, depends on what you are viewing it on if you will notice. If you are having to go below 50%, I would re-author and just select the main movie or split the DVD into two discs.
How about this: Pick one of your store-bought DVD movies, say, a 2 hour one. Back it up in DVDShrink using defaults, output to an ISO and burn to an RW with DVDDecrypter. (Before you hit "Backup" in Shrink, note the compression!!!).
Play it on YOUR setup, whaddaya think? Very soon you'll be forming your own opinions, I guarantee it.
Kidding, but really, your own experience will be your guide. Nevertheless, 34% would indeed be shitty.Pull! Bang! Darn! -
I ran into a similar problem trying to back up "Carlito's Way" (54%, even with just the main movie and most audio/subtitles removed)... decided to make a DivX instead of splitting to 2 discs. Having a standalone that plays MPEG4 has its advantages.
I've done some heavy compression with Shrink and you can get good results on heavily compressed stuff if you use 'max smooth' AEC, but it does take a long time to do the transcoding when using max smooth. I did a 37% and a 40% shrink with Recode a few days ago on some extras on a disc, the results were great considering the amount it was shrunk.
dvdshrink
By Faerel in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2010, 23:07 -
dvdshrink for bluray
By xenotox in forum Blu-ray RippingReplies: 20Last Post: 18th Jul 2009, 09:10 -
Help wanted for DVDShrink 3.2
By _beavis_ in forum Newbie / General discussionsReplies: 13Last Post: 6th Feb 2009, 00:11 -
SVCD2DVD when going to DVDShrink & DVDShrink Re-Author Problems in Vist
By pcandmac2006 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 23rd Jan 2009, 19:33 -
Once I've used DVDshrink, then what?
By craniac in forum Newbie / General discussionsReplies: 3Last Post: 18th Nov 2008, 17:17
