Hi guys. Have just installed new HDD, re-installed XP, re-installed Shrink 3.2. When finishing transcoding in Shrink though, am getting a message box with the message "checking discs.............." continuing through till I click "cancel". Also self ejects the disc. Wasn't getting these before. Any ideas what are, and how to re-set these little annoyances ? There doesn't seem to be anything in Shrink preferences about these. Thanks.
still haven't figured this one out. Did a rip at midnight then dosed off. Woke up next morning, disc ejected, and still 'checking discs......' working away on its own. Any ideas guys ? pretty please...........
Did you set up DVD Shrink to burn after shrinking? What device is selected as the output drive?Originally Posted by cyflyer
Thanks jyn.
Didn't change any settings from default. But in 'file I/O' the 'enable burning with nero' is ticked. Is that what is causing it ?
Output and input device is same. I have only one dvd drive. It was exactly the same set up before. -
The option to "enable burning with Nero" is really mostly intended for people who have two DVD drives. Or, for those who plan to babysit. If you check that option, it will auto-start Nero, look for a blank DVD in your second drive, and begin to burn, with no intervention required.Originally Posted by cyflyer
IF it does not find a blank DVD disc (which is what happens in your case), it just keeps trying, and trying, and trying, and trying... forever. No harm is done, since the files have now been ripped. It is wasting resources, and probably a bit of that DVD drive's laser, every time it checks.
-Bruce in Chi-Town
How to remove annoying "Press Esc to ..." message in Flash Video
By roma_turok in forum User guidesReplies: 517Last Post: 23rd Oct 2017, 10:09 -
AutoMKV hangs with message "first normalizing volume - WAIT" message :(
By Jackie78 in forum Video ConversionReplies: 1Last Post: 25th Dec 2011, 05:33 -
Question about "DMA is not Enabled" warning message on DVDFab Pla
By jimdagys in forum DVD RippingReplies: 14Last Post: 20th Jan 2009, 14:54 -
Does DVD "checking" software really work
By jbartosh in forum MediaReplies: 27Last Post: 16th Nov 2007, 19:45
