This used to work, but won't work for me today. I had S2D extract 2 mpg's
from 2 SVCD BIN-CUEs. The option for chapters every 5 min. is set but I don't get 5-min chapters with this project [it has always worked in the past] .
I tried 2 ways, always starting with the extracted MPGs. Tried 1 Title with the 2 MPGs, tried 2 Titles with 1 MPG each. First way gave 2 chapters, 1 from each MPG. 2nd way gave 2 Titles, each with 1 chapter.
Question is, am I overlooking something or is there a workaround ? I can live with this but would re-run if there are suggestion[s]![]()
TIA P-PA![]()
Is this with RC5?
Originally Posted by ChrissyBoy
If you are suggesting that I retry with RC5, I will, I don't need RC2 for those projects until next week.
Awaiting your advice - p-pa -
There was an issue with RC2 & Chapters. It was fixed in RC3 as i recall. So yes RC5 will give you the chapters you want.
XviD4PSP & Avidemux Doesn't work for me anymore.
By The_Jelly in forum Newbie / General discussionsReplies: 15Last Post: 14th Mar 2012, 08:05 -
Chapters no longer work after adding audio to DVD.
By Nagashi in forum DVD RippingReplies: 4Last Post: 25th Jul 2010, 17:27 -
dv capture and playback doesn't work anymore (except in quicktime)
By richardlode in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 15th Jun 2008, 01:22 -
PAL to NTSC..FAVSC doesn't work anymore and BeSweet Doesn't give me some op
By sandman423 in forum Video ConversionReplies: 13Last Post: 11th Mar 2008, 05:58 -
Philips DVDR7310H: search (Guide Plus) doesn't work anymore
By Monco in forum DVD & Blu-ray RecordersReplies: 1Last Post: 6th Aug 2007, 12:05
