I am encoding a 21 minute show, and trying to stretch it to fit to a whole cd to get the best quality. I'm using TMPGEnc and when I finish setting the source etc and am at the final step it asks what percentage of the cd I want it to take up. The highest it will let me set it is about 60%. If I set it higher it automatically puts it back. How do I maximize the bitrate to take up the whole cd? BTW I'm using 2 Pass VBR setting (but going to try the constant quality setting next time because I heard that's good).
You can't, the svcd max bitrate is around 2600kbits and you would need higher bitrate for a 21 minute clip on a 80min CD(around 800MB), www.videohelp.com/calc ...you can use higher but then it wont be a SVCD.
Madonna's Halftime-What video effect to make entire show look different?
By jimcornetet in forum Newbie / General discussionsReplies: 0Last Post: 6th Feb 2012, 12:40 -
Not entire hardrive showing up
By ramirezi in forum ComputerReplies: 7Last Post: 19th Jul 2009, 12:43 -
Make SVCD from prepared directory
By Gimballon in forum Authoring (VCD/SVCD)Replies: 2Last Post: 18th Jun 2008, 07:35 -
How to make a VCD/SVCD with CD Audio (CDDA)
By Baldrick in forum User guidesReplies: 74Last Post: 24th Dec 2007, 18:37 -
any way to make changes and not to encode entire slide show
By tryintoo in forum Authoring (DVD)Replies: 0Last Post: 9th May 2007, 17:02
